Threading A Horizontal Wire EDM
A wire EDM machine designed for micromachining uses negative air pressure to thread the fine wire.
Makino’s UPJ-2 wire EDM machine orients the wire horizontally. This facilitates micromachining operations requiring fine wire, because the slug falls easily out of the way. One user of this machine is Hummingbird Precision Machine in Lacey, Washington. This video taken at Hummingbird shows how the machine threads the wire. Negative air pressure allows the machine to reliably thread wire as small as 20 microns in diameter.
3 Tips to Accelerate Production on Swiss Lathes with Micro Tools
Low RPM lathes can cause tool breakage and prevent you from achieving proper SFM, but live tooling can provide an economical solution for these problems that can accelerate production.
Where Micro-Laser Machining Is the Focus
A company that was once a consulting firm has become a successful micro-laser machine shop producing complex parts and features that most traditional CNC shops cannot machine.
