HCL CAMWorks
Four Questions (& Answers) About Data-Driven Process Improvement at CNC Job Shops
How can shops can make informed decisions using data-driven feedback to improve shopfloor efficiency and profitability? And how will these technologies differ between high- and low-volume production?
The knowledge we accumulate from our daily work must be worth reflecting upon every now and then, right? After all, if it weren’t for the conclusions we draw from our collected experiences, how would we form and test hypotheses or share unsolicited advice at the bar?
This column will offer a bit of both but lean toward the latter.
My colleague Derek Korn and I were recently asked to select a metalworking and machining topic and conduct a live Q&A about it on the main stage at IMTS 2024 this past September. Readers of MMS will remember Derek as a top editor at Modern for many years before taking the helm of Production Machining as its current editor-in-chief, and together he and I chose the topic and title of the IMTS chat: “The Softer Side of Machining: Data-Driven Process Improvement and Digital Innovation.” The discussion focused on how shops can make informed decisions using data-driven feedback to improve shopfloor efficiency and profitability. The key — and in my opinion what made the conversation interesting — was outlining the distinctions between data-driven manufacturing for high- versus low-volume production. Here is a roundup of what I shared during that discussion:
What are the biggest challenges that machine shops face when transitioning to a data-driven approach?
At the ground level, the cultural shift that data-driven transitions represent at “traditional” job shops is real but often misunderstood. If your shop has employees with long-established workflows and a familiarity with manual or semi-automated processes, it is possible that selling data-driven operations to your operators — not to mention management and other shop leaders — could be challenging. But Modern Machine Shop’s reporting has consistently found that resistance to change is far outweighed by the benefits of implementing data-driven processes. And this doesn’t take into account that many employees, especially younger generations, would rather work in tech-forward environments.
Obtaining buy-in from staff during transitions is key. From the minute your shop plans a new data-driven initiative, create a committee or team to help guide the implementation process. There’s a big difference between introducing workflow changes by telling employees, “Here’s how we’re doing things from now on,” versus saying, “Here are the challenges we’re facing. Let’s solve them together.”
Second, the initial investment in equipment for data-driven systems can be intimidating. Software, sensors and sometimes new machinery may be required, and those investments could represent a barrier to entry. My column last month focused on grant opportunities for machine shops, which could be a viable path for capital expenditures in many situations. In addition, representatives from companies that provide data-driven solutions can help you determine the ROI on these investments and help implement them once purchased. The “do-nothing” scenario is also worth consideration: How expensive is it to replace employees who become fed up working at tired shops with outdated technologies?
Finally, there’s the technology learning curve to consider and the issue of “data literacy” among staff. Learning how to collect, analyze and act on shopfloor data is not always an intuitive process, so ensuring your technology providers provide thorough training is key. Data can be used to streamline production and increase revenue, just as it can be misinterpreted and lead to poor decision making.
How can machine shops maintain balance between automated data collection and human expertise?
Data-driven processes and human expertise are not opposing forces. When treated properly, data enhances the decision-making process, rather than replacing it. Real-time shopfloor data for machine utilization, tool life, production bottlenecks and so on require humans to interpret and act upon that data. Ideally, these decision makers will be your experienced machinists and operators who understand the nuances of your machines, cutting tools and general production flow.
Also keep in mind that many data-driven operations such as predictive maintenance and tool-changing schedules can be set up to provide alerts rather than perform an automated procedure — another opportunity for your experienced staffers to evaluate and validate those alerts before acting. Data can be effectively used to inform their decisions, not make them.
How does the role of data differ between high-volume, low-mix production versus high-mix, low-volume shops?
Since consistency and repeatability are key to high-volume production, process optimization should be the goal for these shops. Data-driven strategies can be used to identify and eliminate small inefficiencies that, over time, accumulate and result in lower throughput and lost revenue opportunities. Low-mix, high-volume shops can leverage data to eliminate variability in machining performance in several ways, including identifying optimal predictive maintenance schedules and fine-tuning processes to achieve consistent, repeatable cycle times.
Tech-forward high-mix, low-volume job shops use data very differently. Data can be used to help track tool management and tool wear and to help automate setups for each unique job, or integrated into ERP systems to manage quality, planning, execution and data inspection processes within a single platform — critical when the goal is to achieve success with the first part. Tool Monitoring Adaptive Control (TMAC) systems can use sensor data to monitor tool life and make real-time adjustments, overriding programmed CNC feed rates when necessary to maintain optimal power through each cut. In other words, data-driven production for high-mix, low-volume shops tend to be process specific, with a goal of achieving rapid changeovers and first-part quality.
What emerging data technologies will have the greatest impact on CNC machining over the next few years?
Digital twins, artificial intelligence, mixed/virtual reality for maintenance and training, end-to-end process control and user-friendly dashboards for real-time data analytics are all digital technologies that exist today but are positioned to expand rapidly in the coming years. If you stay tuned, you can read about each of them right here.
HCL CAMWorks
IMTS+
Metal Forming Complex Parts
JTEKT
PMTS 2025 Register Now!
Machine Monitoring Boosts Aerospace Manufacturer's Utilization
Manufacturer, Integrator, Software Developer: Wolfram Manufacturing is a Triple Threat
Wolfram Manufacturing showcased its new facility, which houses its machine shop along with space for its work as a provider of its own machine monitoring software and as an integrator for Caron Engineering.
Measurement
Process Control — Leveraging Machine Shop Connectivity in Real Time
Renishaw Central, the company’s new end-to-end process control software, offers a new methodology for producing families of parts through actionable data.
Leveraging Data to Drive Manufacturing Innovation
Global manufacturer Fictiv is rapidly expanding its use of data and artificial intelligence to help manufacturers wade through process variables and production strategies. With the release of a new AI platform for material selection, Fictive CEO Dave Evans talks about how the company is leveraging data to unlock creative problem solving for manufacturers.
Workforce Development
HCL CAMWorks
