Finishing A Pocket Floor In Titanium
Machining animation from Boeing illustrates effective techniques for titanium workpieces. This simulation also shows finishing of the floor of the pocket.
Like the previous simulation in this series, this machining simulation provided by Boeing Research and Technology (using CGTech software) shows roughing followed by material removal from the corners prior to finishing. The finishing of the walls is performed with fast passes at successive layers.
This simulation also shows finishing of the floor of the pocket. Note how the tool radiates out from the center of the pocket to the wall. This keeps unmachined stock always adjacent to the cut for support. No section of the floor is ever touched again after it has been machined once.
Find details in the articles at right. Or, see other videos in this series:
1. Video: Finishing Walls In Titanium
2. Video: Finishing A Pocket Floor In Titanium
3. Video: Plunge-And-Sweep For Finishing Corners
Sandvik Coromant Launches New Range of Solid End Mills
The CoroMill Dura range is designed for roughing and finishing with different engagements in all applications and materials.
ANCA Creates Solid PCD-Tipped Helical End Mills, Drills
The company’s Edge machine is capable of creating complex 3D cutting tool forms, including solid PCD-tipped end mills and drills under 1 mm.
