Wanna Give MQL a Try?
If you own a Haas machine, here’s your chance to give minimum quantity lubrication a try.
![](https://d2n4wb9orp1vta.cloudfront.net/cms/uploadedFiles/DK_unistmqlhaas(1).jpg;maxWidth=600)
For more information and/or to be considered for an onsite beta test, contact Unist. And tell them Modern Machine Shop sent you.
Rego-Fix Toolholding System Reduces Coolant Consumption
High-Speed Videos Analyze Machining Processes in Fine Detail
Blaser Swisslube captures the machining process, chip formation and behavior of its Synergy 735 metalworking fluid through high-speed, macro photos and videos.
AFT's Semi-Synthetic Coolant Extends Sump Life
Advanced Cool 2200 provides high visibility while machining, keeping the machine and parts clean with no odor issues.
