Video Borescope Kit Comes in Waterproof Carrying Case
Westec 2017: Gradient Lens Corp. introduces a Deluxe Kit for its popular Hawkeye V2 video borescope.
Gradient Lens Corp. introduces a Deluxe Kit for its popular Hawkeye V2 video borescope. The kit includes a four-way articulating V2 videoscope, all standard V2 accessories, the V2 stand, V2 Rigidizer, the 90-degree prism tip and the close-focus tip. The kit is available in diameters of either 4 or 6 mm, and in lengths of 1.5, 3.0 or 6.0 m.
The V2 Deluxe Kit also comes with a Hawkeye V2 carrying case. The case is injection-molded, waterproof and molded of ultra-high-strength polypropylene copolymer resin. It is resistant to corrosion and impact damage.
