Technology Corrects Spindles Working Independently
EMO 2017: Licon will present its i3 technology, which enables correction of spindles working independently of each other.
Licon will present its i3 technology, which enables correction of spindles working independently of each other. The technology provides basic configuration independence in the Z axis and enables independence in all three linear axes.
In addition, the company will show its Licon Added Value Analysis (LAVA) interface and its Liflex machining centers. The LAVA interface gives read outs and evaluations of force, vibration and temperature to help prevent downtime, and provides daily reports so users can set up preventative maintenance, optimize processes and maximize output. The Liflex machining centers are designed for minimum quantity lubrication and can save customers money on power, tools and investment, according to the company.
Shop Replaces Two Verticals With One Horizontal
By trading two VMCs in to help finance the purchase of a new HMC, this shop was able to significantly increase production and move to lights-out machining.
Large-Format Machining Simplifies Tube Manufacturing
Downtime is the enemy of efficient manufacturing — a problem FIBA Technologies has addressed through purchasing a Soraluce FLP 14000.
