Separator Solves Tramp Oil Dilemma
Debco Machine, Inc. (Natick, Massachusetts), a job shop specializing in precision components from aluminum, plastics and stainless steel, was faced with what it characterized as a particularly demanding requirement for tramp oil removal from the sump of a Matsuura 510 vertical machining center, a machine that is in nearly constant use. About 1 gallon per day of tramp oil enters the 100-gallon coolant sump of this machine.
Parts produced by the company are incorporated in robotic devices, dissolution machines used in the development of drugs, respirators, soldering devices and other applications requiring tight tolerances. Debco runs at full capacity, even during slow periods. To this end, there is no time available for machines to be off-line for cleaning and adjustment.
Dan Collari, owner and shop manager, was particularly concerned with maintaining the productivity of the machining center, realizing that the presence of a large quantity of tramp oil in the coolant was adversely affecting machine throughput, tooling life and parts finish.
“This particular Matsuura machine is online continually,” says Mr. Collari. “It does a little bit of everything, which can lead to problems. We may have a precision stainless steel job following one involving plastics or aluminum, leaving a considerable quantity of suspended chips and fines in the coolant.”
If the coolant is not cleaned routinely, then the plastic or aluminum solids are picked up by the coolant pump and sprayed onto the precision stainless working part. A further complication is that the 100 gallon sump is divided into three compartments, and removing the tramp oil from only one compartment—for example, using a conventional belt skimmer—does not reduce the oil in the other compartments.
Mr. Collari says the problem required immediate attention, given the significance of the machine. He surmised that using a dedicated separator, rather than a portable unit that would treat all of the machines in the shop sequentially, was the most appropriate course of action. Familiar with conventional separators, Mr. Collari concluded that they would not be suitable to address the shop’s dilemma. Another requirement was that the separator should require little or no attention from the machine operator, the company says.
“When an operator who has worked an 8 or 9 hour shift suddenly sees that the coolant cleaner has plugged or is flooding, he/she may be tempted to shut down the unit and forget about it,” speculates Mr. Collari.
Belt skimmers and disc skimmers do not remove floating solids; they do not circulate the coolant to clean all segments of the large sump, says the company. Among other candidates, the Model TKO-6, part of a family of separators for individual sumps offered by Keller Products, Inc. (Acton, Massachusetts), was evaluated as a potential solution.
Having used portable Keller units on other machines for several years, Mr. Collari says he was quite familiar with the company’s line of separators. The model TKO-6 possesses several features that made it suitable for this application, particularly the fact that it is equipped with a 1/2-inch compressed, air-operated diaphragm, says the company.
According to the manufacturer, the inclusion of 1/2-inch pump, as opposed to the 1/4-inch diaphragm pumps or electric pumps used on small separators, is conducive to enhancing performance and reliability. The pump enables the separator to readily deal with the large volume of tramp oil in this particular sump. The flow rate of 3 gpm, which continually turns over the 100-gallon sump nearly twice per hour, aerates the coolant and creates vigorous circulation, in turn forcing oily coolant to the inlet device from all areas of the sump. The flow rate through the oil separation section can be modulated to obtain a clean split of tramp oil from a slow-rejecting coolant without affecting the overall coolant recirculation rate.
“Maintenance of a 1/4-inch diaphragm pump is no picnic,” says Mr. Collari. “I’ve found that the 1/2-inch pump keeps running, without maintenance being an issue. In addition, the model’s 14-inch by 14-inch footprint is crucial because of the limited floor space in the shop.”
Containing no replaceable parts, the separator can be set up when the user clamps the inlet device to the filter inlet using the hose provided. According to the manufacturer, the filter on the inlet side is a common feature to all of its oil separators and can protect the pump from damage by chips and other solid particles. In addition, the permanent plastic oil separation element does not require cleaning or replacement.
The collected tramp oil is drained from the separation tank by opening the drain valve briefly, usually once per day, according to the company. The prefilter screen is cleaned once every 2 weeks—about a 5-minute task.
Happy with the separator’s performance, Mr. Collari reports that the Matsuura is operating at optimum efficiency and that his staff no longer wastes time tinkering with the coalescing unit.
STLE Hosts Co-Branded Tribology, Lubrication Events
The 2023 STLE Tribology Frontiers Conference and Tribology & Lubrication for E-Mobility Conference will provide attendees with two opportunities to share and learn the latest tribology and lubrication engineering science.
Read MoreJorgensen Introduces Sustainable Conveyor, Material Handling, Coolant, Filtration Solutions
IMTS 2024: Jorgensen Conveyer and Filtration Solutions announces a lineup for conveyor, material handling, coolant and filtration solutions, including the EcoFilter80 self-cleaning system, the PermaClean system and others.
Read MoreHigh-Speed Videos Analyze Machining Processes in Fine Detail
Blaser Swisslube captures the machining process, chip formation and behavior of its Synergy 735 metalworking fluid through high-speed, macro photos and videos.
Read MoreIMTS 2022 Review: Attention to Automation Extends Beyond the Robot and the Machine
