PCD Grade Improves Surface Finish in Engine, Chassis Applications
Element Six’s CTB004 PCD grade is designed to meet the precision cutting demands of the automotive industry.
Element Six’s CTB004 PCD grade is designed to meet the precision cutting demands of the automotive industry. Offering high-speed machining advantages, the PCD grade delivers optimized workpiece surface finish in engine and chassis applications. It is ideal for cutting aluminum alloys requiring high surface finish and higher wear resistance.
The grade’s 4-micron, fine-grain structure balances tool performance with resistance to abrasion and chipping. Ideal for complex machining requirements, it offers commercial advantages for end users due to the reduction in downtime and improved productivity.
Kyocera Turning Grade Provides Tough Cutting Edge
The Megacoat Tough coating combines a wear-resistant layer on the surface adhered to high-content CBN, which provides greater fracture resistance when encountering interruptions.
Walter Ceramic Inserts Enable Efficient Turning, Milling
Suitable turning and milling applications of the WIS30 ceramic grade include roughing, semi-finishing and finishing, as well as interrupted cuts.
