Mold Maker Raises Productivity With Software
George Kasper, president of Innovative Mold, incorporated the company in 1989 with his brother David. The Washington, Michigan, firm began by making molds for the plastics industry.
George Kasper, president of Innovative Mold, incorporated the company in 1989 with his brother David. The Washington, Michigan, firm began by making molds for the plastics industry. It now employs 26 people and produces 90 percent of its molds for the automotive industry for presses between 50 and 500 tons. Innovative Mold manufactures single-shot molds and two-shot rotational molds, producing interior parts, structural components and sound damping items.
“The appearance of many of the interior parts is critical,” Mr. Kasper says. “For example, a radio bezel may require two different resins injected to produce the required quality and appearance. We can offer rotational molds or pick-and-place robot transfer solutions to achieve the desired results in demanding applications such as this one.”
Innovative Mold installed its first CNC machinery in 1996. Today, its Toshiba and Cincinnati molding machines provide a means by which to conduct trial runs. The company manufactures prototype tooling in aluminum or steel depending upon the customer’s individual requirements.
Over the years, mold complexity increased, while machine tools became more sophisticated. The company acknowledged that its existing CAM package had some shortcomings, especially when dealing with P20 steel.
When Innovative Mold initially considered WorkNC from Sescoi USA, Inc. (Southfield, Michigan), it felt that it could not justify the cost. However, a successful trial run conducted by the company’s engineers persuaded George Kasper that the software would be a good fit for his business.
“WorkNC spends more of its time actually cutting, which has resulted in a productivity increase of between 25 and 50 percent through more efficient tool paths,” Mr. Kasper explains.
“Programming is nearly three times quicker with WorkNC when compared to our previous software package,” adds Quinn Sova, programmer at Innovative Mold.
CAD data is passed from the company’s design systems to WorkNC, which is dedicated to the preparation of CNC code.
“The cycles we use most frequently in WorkNC are high-torque roughing, high- torque reroughing, Z-leveling, Z-level remachining, planar finishing, optimized Z-level finishing, contour remachining, and tangent-to-curve and on-curve engraving, Mr. Sova says. “This gives us the flexibility to easily complete the most complex work.”
Because of the program’s reliability and capability to generate smooth tool paths, Innovative Mold says that it can use spindle speeds as fast as 28,000 rpm and feed rates between 0.04 ipm and 250 ipm, as well as cutters with diameters as small as 0.012 inches on titanium workpieces. A major contributor to success has been the re-machining function, which Innovative Mold uses extensively. After each machining operation, WorkNC can update the stock material model so that it knows exactly where excess material remains. Armed with this information, the software ensures that the tool is continually engaged with the job for the subsequent operation. The manufacturer says that this maximizes productivity and minimizes shock loading, which could lead to tool breakage.
“The roughing cycles have saved us a considerable amount of time,” Mr. Sova explains. “The capability of WorkNC to machine more of the mold directly has contributed to a reduction in the number of electrodes that we have to make as well.”
WorkNC is a valuable element in the parallel processes that Innovative Mold operates. When the customer orders the mold, the company raises an order for the steel during the design evaluation phase. Similarly, mold manufacturing begins as the design is being finalized, enabling it to continuously build as much of the tool as possible in parallel with other tasks. According to the company, this reduces lead times.
“WorkNC has cut programming and machining times,” Mr. Kasper says. “We have reduced delivery on aluminum prototype tools to 2 weeks and production tools to 8 weeks.”
“WorkNC is an integral part of our production process and an efficient means of programming cutter paths,” he says.
YCM Alliance Hits IMTS
Read MoreGrob Systems Inc. to Host Tech Event With Industry Partners
The 5-Axis Live technology event will highlight new machining strategies for optimizing the production of complex medical, aerospace and mold/die parts.
Read MoreTool and Die Shop Discovers New Opportunities With First CNC Machine
In a shop that stamps millions of parts per year, the arrival of a CNC machining center is opening new pathways for production and business.
Read MoreFor This Machine Shop, Licensing Is the Answer to the Inventor’s Dilemma
Machine shops are natural inventors, but not necessarily suited to supporting and marketing a product. This Minnesota shop with an invention related to micromolding will share it through licensing.
