Machining Centers Maintain Rigid, Stable Performance
This month’s curation of products focuses on a diverse variety of machining centers.
March issue’s Modern Equipment Review Spotlight highlights horizontal, vertical, five-axis and multitasking machining centers. One standout attribute among the machines in this curation is stability. From the Tongtai CT-350’s wide, torsion-resistant column to the Super 1320’s pre-loaded C3 ballscrews on all three axes, a number of features on these machining centers serve to maintain rigidity and stability for precise operation, even with some large and unwieldy workpieces.
Click the image above to be taken to a slideshow featuring these and other machining center products with links to more information.
Horizontal High-Speed Machining Saves Hundreds of Work Hours
High-speed machining is the latest change at Blair-HSM South, helping this once old-fashioned shop improve productivity and morale while enabling new work.
