Just a Touch More Capacity
“Automated” does not have to mean utterly unattended. What many shops need is to find just a little more productive capacity with their existing staff and equipment.
“Automated” does not have to mean utterly unattended. What many shops need is to find just a little more productive capacity with their existing staff and equipment. One valuable automation device might already be in the shop—that is, the spindle probe that came with the CNC machining center.
In this application, a manufacturer that increased its number of machining centers by 80 percent (from 6 to 11) managed to increase its productive capacity by more than 800 percent. The difference was the implementation of probing, allowing the machines to “feel” for the location of parts, eliminating the need to position each part precisely through a manual setup. In this way, what used to be a 90-minute setup is now 10 minutes, leaving 80 more minutes for machining. The company obtained new capacity not just by buying new machine tools, but also by discovering more capacity on its existing machines.
In certain cases, the probe can even be used to measure a finished part. This article provides an example. In this exchange with a reader, the various uses of the machining center probe are concisely summarized.
Okuma America Double-Column VMC Features Compact Footprint
The new Genos M560V-5AX offers a working envelope with a 500 mm table and wide axis travels, while still maintaining a compact footprint of 2,515 mm × 3,750 mm.
Three-Axis Bridge Mill Opens New Doors for Construction OEM
Different industries often require different machining priorities, a truism recently demonstrated by Barbco, an OEM of heavy-duty boring equipment that opened up new design possibilities by pivoting toward rigid, less complex machining centers.
Mitsui Seiki's Compact VMC Offers High-Precision Milling
The VL30 series is designed to machines high-precision mold inserts for medical, packaging, industrial and aerospace applications.
