3D Printing Machine Training
IMTS: The Name Change Makes Even More Sense Today
With the rapid expansion of additive manufacturing’s place at the show, the biennial event expands well beyond machine tools.
Is an additive manufacturing machine a machine tool? Arguably not, and the organizers of IMTS decades ago seemed to anticipate that a technology such as this might one day be part of the show.
Back in 1990, the bienniel manufacturing event changed its name, choosing a new name that its initials could take in stride. What had been the International Machine Tool Show became the International Manufacturing Technology Show.
Nevertheless, IMTS has remained largely a machine tool show, with its biggest halls devoted to showcasing these machines. Most of the products exhibited­—tooling, workholding, manufacturing software, measurement devices—are just one step removed from a machine tool. This year, however, will we see a significant departure from the show’s historical norm?
The answer depends on one’s answer to the question I started with: whether a machine for additive manufacturing (AM) is a machine tool. IMTS is still advancing as a major event for AM. The leading event in North America for manufacturing decision-makers, it is the right venue for companies supplying additive offerings. Accordingly, triple the number of companies are exhibiting in the show’s Additive Manufacturing Pavilion this year compared to the last show—and that’s just the AM Pavilion. The number of machine tool builders and software companies showing additive-related solutions in the rest of the show has expanded as well. So is this technology just an incremental extension? Is additive a new and different machine tool variety?
The questions are important because the answers shape what one is able to see in the technology.
My answer is “sometimes yes,” in that a hybrid machine tool offering additive capability clearly is still a machine tool. Beyond that, my answer is “mostly no.” An additive manufacturing machine generating a complete part through AM is not a machine tool, because it does not do what a machine tool does. It does not fill the same niche. It changes the niche instead.
An AM machine can make a part that otherwise might have been machined. In that case, it takes the place of machine tool. But it can also consolidate connected parts into one piece. In that case, it takes the place of assembly. It can consolidate operations such as casting, machining and assembly into one step, taking the place of a supply chain and the shipping that links that chain. It can simplify the supply of aftermarket components, taking the place of a warehouse full of parts. It can open the way to entirely new possibilities in design, replacing design for manufacturability with design for functionality.
In short, additive touches so much of the process that it is less a manufacturing operation and more a manufacturing redefinition. It is less of a resource for the manufacturing department and more of a reshaping of the manufacturing enterprise.
There is more than this to say about additive. My observation here relates to IMTS. Manufacturing is changing, and AM is a significant part of the change. In pursuing and making a home for what is new in manufacturing, additive in particular, we see IMTS continuing to come into its own. We see the show living up to its name.
Acquire
Airtech
World According To
RazorStar
PMTS 2025 Register Now!
Metal Forming Complex Parts
Tsugami Lathe, Vertical Machining Center Boost Machining Efficiency
IMTS 2024: Tsugami America showcases a multifunction sliding headstock lathe with a B-axis tool spindle, as well as a universal vertical machining center for rapid facing, drilling and tapping.
IMTS
Solid Diamonds and a Speakeasy: Meeting Q-Mark Metrology
Q-Mark has built its metrology business by providing what customers need, when they want it. This goes for its IMTS booth, too, with free drinks alongside custom technology.
IMTS
Emuge-Franken Skiving Tools Improve Precision for Tool Grinding Machines
Emuge-Franken USA is showcasing its line of clamping and skiving tool solutions, designed to improve precision and accuracy in tool grinding machines.
IMTS
Keyence Multi-Sensor Measuring System Targets Quality Control in Metrology
IMTS 2024: Keyence introduces the LM-X Series Multisensor measurement system for high-performance measurement, automated inspection processes, accuracy and quality control.
Automation
3D printing machine trainings
