High Speed Air Spindle Example 3: Robotic Deburring
Using an air spindle, this Fanuc robot is able to deburr castings with irregular flash.
The model 725JSL motor-mount spindle with compliance unit from Air Turbine Tools is used to deburr an aluminum casting on a Fanuc robot. The deburring tool is rotated at a constant 40,000 rpm and advanced at 5,000 ipm. The compliance unit on the robot enables the customer to deburr parts with irregular flashes after the initial casting operation. The spindle model’s low vibration is said to make it well-suited for such robotic deburring applications.
Four-Axis Horizontal Machining Doubles Shop’s Productivity
Horizontal four-axis machining enabled McKenzie CNC to cut operations and cycle times for its high-mix, high-repeat work — more than doubling its throughput.
Using the Toolchanger to Automate Production
