High Pressure Coolant Reduces Friction
High Pressure Coolant from CoolJet Systems increases throughput, reduces process cycle times, improves surface finishes, improves chip control, reduces the number of processes and increases tool life. Suited for applications such as drilling, grooving and boring, the cutting fluid can also be used for cutting exoti
High Pressure Coolant from CoolJet Systems increases throughput, reduces process cycle times, improves surface finishes, improves chip control, reduces the number of processes and increases tool life. Suited for applications such as drilling, grooving and boring, the cutting fluid can also be used for cutting exotic materials. The cutting fluids are pumped to pressures of 1,000 psi or more to penetrate the high-temperature cutting zone in order to reduce friction and lower the temperature.
Hennig Inc. Acquires Industrial Coolant Systems
ICS develops and field tests high-pressure coolant systems, coolant filtration systems and other machine tool solutions.
Henkel Redefines Industrial Machining and Grinding with Sustainable Metalworking Innovation
With innovative formulation and bio-resistant properties, Henkel’s new semi-synthetic lubricant emerges as a pioneering solution in the machining industry.
High-Speed Videos Analyze Machining Processes in Fine Detail
Blaser Swisslube captures the machining process, chip formation and behavior of its Synergy 735 metalworking fluid through high-speed, macro photos and videos.
