Controlling Burr Formation within Small Intersecting Holes
A reader struggles with burrs between intersecting holes 1 mm and less in diameter. MMS Online’s micromachining expert offers advice.
A reader recently used the “Ask an Expert” feature of our Micromachining Zone to ask about a challenge in milling with a relatively small tool on one of his existing machines.
Question
At the junction of a 1 mm hole and a 0.3 mm hole, we struggle with burr formation. How can we reduce this? We use three drills, for center, pre- and finish drilling.
Response from John Bradford, micromachining R&D team leader for Makino
This is an area where much time and research has been spent. At this time, my only recommended process countermeasures might be:
● Support material—After machining the first hole, is there a means to plug or fill the cavity void, thus creating a "backing" material for the intersecting hole to meet? This helps reduce or eliminate the chip formation as the tool is breaking out, or the chip pushing away when the drill breaks through.
● Altering workpiece temperature—Generally speaking, burr formation characteristics change as the temperature of the material changes.
● Feeds and speeds—Burr formation can be minimized (but not eliminated) by increasing spindle speed and slowing feed rate. However, higher tool wear may occur.
I have also seen several related published papers from UC Berkeley, from Professor David Dornfeld. You can find him here: http://www.me.berkeley.edu/faculty/dornfeld.html.
Where Micro-Laser Machining Is the Focus
A company that was once a consulting firm has become a successful micro-laser machine shop producing complex parts and features that most traditional CNC shops cannot machine.
3 Tips to Accelerate Production on Swiss Lathes with Micro Tools
Low RPM lathes can cause tool breakage and prevent you from achieving proper SFM, but live tooling can provide an economical solution for these problems that can accelerate production.
