HCL CAMWorks
California Specialty Parts Machinist Has No Room For Error
Much of the current equipment at this plant is German and Swiss machinery, including two Deckel mills (FP4 and FP3), a Bridgeport mill and Schaublin (10-inch) and HES (20-inch) lathes, among other various saws. In order to keep the parts as accurate as possible, the controls and DROs that are used need to be accurate and reliable.
Group 5 Engineering Inc. (El Segundo, California) specializes in machining high-end parts for two very different worlds: One is for the commercial aviation industry, and the other is for specialty custom hardware used in fine homes. Many aviation-type parts are machined there, including rudder posts, throttles and yolk shakers (stall indicators) for big aircraft; cargo door latches of various sizes; dampers; and various hydraulic test fixtures. The custom home hardware ranges from solid stainless steel fancy drawer pulls and huge front door handles with solid backing plates to special bronze grates for pools and showers.
All of this specialty work is being coordinated by company owner Rich Ushler. And he has no room for error.
"Some of the parts I do are worth $75,000, so if I make a mistake, I'd have to mortgage my house," he says. Mr. Ushler is no stranger to the machining world, as he has been involved in it for about 30 years, and his small shop is now known in this California area as a place for expert part machining.
The high accuracy of Group 5 Engineering's work is of utmost importance, and the company is called upon again and again because of this expertise . . . as well as because of the reliability and accuracy of the equipment. Much of the current equipment at Group 5 Engineering is German and Swiss machinery, including two Deckel mills (FP4 and FP3), a Bridgeport mill and Schaublin (10-inch) and HES (20-inch) lathes, among other various saws.
In order to keep the parts as accurate as possible, the controls and DROs that are used need to be accurate and reliable. The shop found what it needed in Heidenhain (U.S. subsidiary in Schaumburg, Illinois).
"When you are dealing with such expensive parts, it is imperative to be certain where you are," explains Mr. Ushler, "and I am confident about my position with the Heidenhain feedback." Mr. Ushler's affinity for Heidenhain began almost two decades ago when he purchased a Bridgeport machine with a Heidenhain control already on it. "It was accurate, reliable and easy to use even then," continues Mr. Ushler.
Since then, when Mr. Ushler decides he needs to automate or increase the accuracy of his manual equipment, he systematically turns to Heidenhain, often to its digital readout (DRO) systems (or "RETROKITs" for both mills and lathes).
"They work, I understand them, and they are reliable," he says. The Heidenhain RETROKITs typically consist of a two-axis DRO and two sealed glass optical linear scales complete with armor shielded cables, custom designed brackets and arm/tray assembly for easy installation.
They are offered in various sizes. The optical linear scales vary per application, but they typically:
  • have a grating period of 20 microns (50 pulses per millimeter),
  • have an accuracy grade of ±10 microns,
  • have distance-coded reference marks and
  • are rated IP 53 (ideal for shop floor environments).
At Group 5 Engineering, Mr. Ushler has one mill that is at least 20 years old that had, at that time, been retrofitted with Heidenhain's VRZ 710 readout and its LS 603 glass optical linear scale. "The scale has performed flawlessly and is still working," says Mr. Ushler.
Mr. Ushler continues to rely on Heidenhain feedback systems for their accuracy and reliability. His latest lathe retrofit consists of Heidenhain's ND 730 DRO and its LS 603 linear scales. "If these systems save me from making a single mistake, they've paid for themselves," says Mr. Ushler, "and they do."
Also, much to Mr. Ushler's happiness, his Deckel machines already came equipped with Heidenhain.
"My Schaublin lathe is my only large machine that is manual," states Mr. Ushler, "and I do plan a DRO system purchase from Heidenhain in the near future to increase its accuracy."
HCL CAMWorks
JTEKT
PMTS 2025 Register Now!
Metal Forming Complex Parts
Automation
Cutting Part Programming Times Through AI
CAM Assist cuts repetition from part programming — early users say it cuts tribal knowledge and could be a useful tool for training new programmers.
Five-Axis
The Power of Practical Demonstrations and Projects
Practical work has served Bridgerland Technical College both in preparing its current students for manufacturing jobs and in appealing to new generations of potential machinists.
Sponsored
Sponsored
Automated CAM Programming – Is Your Software Really Delivering?
A look at the latest automation tools in Autodesk Fusion 360 software and how forward-thinking machine shops and manufacturing departments are using them to slash delivery times and win more business.
Workforce Development
HCL CAMWorks
