Build the Machine around the Workpiece
Rather than fitting a part into an existing machine, modular machining units enable building a custom machine particularly suited for that workpiece. This approach is best for large production runs of specialized parts.
It makes sense to cut, mill, drill or tap a workpiece on the machine best-suited to the task, but sometimes it makes even more sense to assemble the machine tool specifically for the workpiece. Suhner Automation offers a range of machining units that can be combined into complete machining systems for large runs of specialized parts, especially those that are bulky or awkwardly shaped such as automotive and aerospace components.
The machining units, which can perform sawing, milling, drilling and tapping processes, can be arranged to operate simultaneously or in sequence. A display at the company’s IMTS booth, for example, showed how multiple drilling units could be arranged to drill multiple holes on the interior of a Corvette door in one pass (pictured above). Meanwhile, a separate demonstration featured a machining center consisting of four different types of machining units to demonstrate how workpieces could be machined complete in a single setup. Each time the machine indexed, it produced a finished part.
Each machining unit consists of a pneumatic spindle and toolholder with a durable cast iron body. The units are available in a range of different sizes with through-coolant variations and can be equipped with servomotors and ballscrews for greater accuracy. Suhner also provides the enclosures and systems necessary to form complete machining centers with the modular units.
Small Hole EDM Drill With Automation
The SY-4060 is a part of a lineup of CNC EDM drills from Belmont Equipment & Technologies.
Horizontal High-Speed Machining Saves Hundreds of Work Hours
High-speed machining is the latest change at Blair-HSM South, helping this once old-fashioned shop improve productivity and morale while enabling new work.
