Video: Hard Pocket Milling
Relieved end mills and pre-machining of corners are two important considerations for accurate pocket machining in hard steel.
This tutorial from video contributor Todd Schuett discusses some of the keys to accurate milling of pockets in hard steel. The specific application involves milling of slide pockets at Allcraft Mold in Schaumburg, Illinois. The video explains the importance of relieved end mills and pre-machining of corners, and also gives various other tips for precise pocket machining.
Ceratizit Expands Range of Indexable Milling Tools
MaxiMill 491 features eight cutting edges per newly expanded 9-mm insert size, a precise 90° profile and a durable, nickel-coated tool body.
