Mitsubishi EDM
Video: DAPRA High-Feed Cutting 316L Stainless Steel at 120 IPM
(Sponsored Content) Dapra's 2" Mid-Feed Shell Mill video
Loading the player ...
This video demonstrates Dapra's 2" Mid-Feed Shell Mill executing a Z-level roughing routine in 316L stainless steel. The machine tool used is a Fadal 4020 with a 40-taper spindle.
This video demonstrates Dapra's 2" RHINO-FEED 5-flute Shell Mill and inserts
executing a Z-level roughing routine in stainless steel. The material is 316L, and
the machine tool used is a Fadal 4020 with a 40-taper spindle.
This routine uses Dapra’s mid-feed inserts from the new RHINO-FEED product
line. The inserts are 3/8” IC and offer 4 usable edges. Outstanding metal
removal rates are possible on lighter duty machines using this method.
The parameters for this video are:
2” RHINO-FEED Mid-Feed Shell Mill – 5 Flute
316L Stainless Steel Material
350 SFM (670 RPM) .035 FPT (120 IPM) .035" DOC
Variable WOC up to 100%
Mitsubishi EDM
Thermo SL EDM Wire
EZ Access - Have it all with Ez - Mazak
The Automated Shop Conference
Mitsubishi EDM
