Sponsored Video: Helically Interpolating a Hole at 225 IPM Through a Milled Slot
This video demonstrates Dapra's 1" Toroid End Mill executing the helical interpolation of a 1.75" diameter hole to a depth of 1.25". The material is H13, and the machine tool used is a Fadal 4020 with a 40-taper spindle.
Nidec Universal Head Enables Versatile Machining
The compact universal head enables better accessibility between the tool and the workpiece, as well as improved surface-finish quality, greater motion range and high-efficiency machining under ideal machining conditions.
