Pivot™180 - the Oscillation Sensation!
(Sponsored Content) Pivot 180 generates airflow 100 feet out, enveloping a 180 degree arc from side to side – a coverage area of an impressive 12,000 square feet. Pivot 180 installs on a column or other vertical structure proving the perfect air movement solution for areas with ceiling obstructions or tight spaces.
Loading the player ...
