Finishing Walls In Titanium
Machining animation from Boeing illustrates effective techniques for titanium workpieces. This video shows material machined out of the corners prior to finishing.
This machining simulation provided by Boeing Research and Technology (using CGTech software) illustrates some of the practices of effective milling of titanium that are detailed in articles under “Editor Picks” at right.
After the initial roughing, the video shows material machined out of the corners prior to finishing. This is followed by finish milling at successive layers instead of milling the full wall depth at once. These fast finishing passes are often performed using an end mill with many flutes—such as a 5-, 10- or even 20-flute tool.
Find details in the articles at right. Or, see other videos in this series:
2.
Video: Finishing A Pocket Floor In Titanium3. Video: Plunge-And-Sweep For Finishing Corners
Form Tapping Improves Tool Life, Costs
Moving from cut tapping to form tapping for a notable application cut tooling costs at Siemens Energy and increased tool life a hundredfold.
Shoulder Milling Cuts Racing Part's Cycle Time By Over 50%
Pairing a shoulder mill with a five-axis machine has cut costs and cycle times for one of TTI Machine’s parts, enabling it to support a niche racing community.
