Exit-Side Drill Penetration Without Delamination
Slow-motion video shows the effect of a micograin tool coating in drilling CFRP.
Cutting tool maker OSG says a patented coating process keeps the micrograin structure of its diamond coating to less than 1 micron. Coating typically rounds the edge of a tool, but the smaller micrograins produce a coated tool that is sharper. The result, says OSG, is less tradeoff between the tool life of diamond and the delamination that can result from a duller tools. This video shows this. The sharp edge of the small-micrograin diamond-coated tool lets this tool exit the hole much more cleanly.
Increasing OEM Visibility to Shopfloor Operations for the Win
A former employee of General Motors and Tesla talks about the issues that led to shutdowns on factory lines, and what small- to medium-sized manufacturers can do today to win business from large OEMs.
