90-Degree Pocketing Aluminum - 0.250” DOC with Square Shoulder End Mill and XPET-ALU Inserts from Dapra
(sponsored content) This video demonstrates Dapra's 1" Square Shoulder End Mill executing a pocketing routine in aluminum.
Loading the player ...
This video demonstrates Dapra's 1" Square Shoulder End Mill executing a pocketing routine in aluminum. The material is 6061 aluminum, and the machine tool used is a Fadal 4020 with a 40-taper spindle.
This particular pocketing routine utilizes a polished, 16mm XPET-ALU insert for more depth of cut capability at an aggressive feed rate. The MRR (metal removal rate) for the cut is 60 cubic inches/minute. The cut shown is done without coolant in order to provide better visibility. Good coolant flow is generally recommended.
The parameters for this video are:
XPET1604-ALU Inserts
6061 Material
2000 SFM (7640 RPM)
.026" IPT (400 IPM)
.250" DOC
.600" WOC
40 Taper VMC
Ceratizit Expands Range of Indexable Milling Tools
MaxiMill 491 features eight cutting edges per newly expanded 9-mm insert size, a precise 90° profile and a durable, nickel-coated tool body.
10 Tips for Titanium
