Video: Two-Spindle Inverted Vertical Turning
See how Emag's vertical turning center reduces "nebenzeit."
Machine tool maker Emag says the advantage of a two-spindle inverted vertical turning center is the way it cuts down on “nebenzeit,” or non-productive time. As this video of the company’s VL 2 P demonstrates, one spindle can pick up a part while the other is engaged in machining. As a result, load/unload time is effectively zero.
Kaast Machine Tools Updates Dual-Spindle Lathe
4 Tips for Staying Profitable in the Face of Change
3 Tips to Accelerate Production on Swiss Lathes with Micro Tools
Low RPM lathes can cause tool breakage and prevent you from achieving proper SFM, but live tooling can provide an economical solution for these problems that can accelerate production.
