Video: Manufacturing of the Machined Direct Drive Drum Pedal
Music-industry manufacturer DW Drums discusses in-house production, machining of its new pedal design and working with extruded parts.
Machining is so important to DW Drums’ latest pedal design that machining is part of the product’s name. In this video, Rich Sikra, the company’s vice president of manufacturing, discusses the production of the Machined Direct Drive pedal, the advantages of having that production in-house, and how the company has saved cost by using extrusions instead of machining from rectangular blanks.
I visited DW Drums as part of a film shoot for a forthcoming Edge Factor documentary on music-industry manufacturing. Find updates about the progress of this project at edgefactor.com.
Three-Axis Bridge Mill Opens New Doors for Construction OEM
Different industries often require different machining priorities, a truism recently demonstrated by Barbco, an OEM of heavy-duty boring equipment that opened up new design possibilities by pivoting toward rigid, less complex machining centers.
