Parts Cleaning Workshop at PMTS 2025
Waterjet Diamond Cutting Head Offers Integration, Versatility
Barton International’s Trident-2 diamond cutting head for high-pressure waterjets is designed to offer the advantages of an integrated diamond design with the versatility of a replaceable orifice cartridge.
Barton International’s Trident-2 diamond cutting head for high-pressure waterjets is designed to offer the advantages of an integrated diamond design with the versatility of a replaceable orifice cartridge. Each cutting head cartridge is precision-machined around a simulated jet stream to improve orifice-to-nozzle alignment, resulting in a system that reduces wear and direct increased cutting force, the company says. The replaceable diamond cartridge can be swapped out when a different orifice size is required. The cutting head is said to result in improved accuracy, longer nozzle life and faster cutting with reduced abrasive consumption.
Pickelx one step metal prep
vacuum vapor degreasers
Quality cleaning solutions
Precision Cleaning Solvents
Vacuum Degreasers and Aqueous Solutions
