I had the chance to work with TechSolve, the machining consulting firm based in Cincinnati, Ohio, on filming some really ugly machining passes.
The point was cutting force analysis. Watching poorly performing cuts while also seeing the corresponding cutting force profiles illustrates what force measurement can reveal about the process. In many cases, force monitoring is limited to the machine’s spindle-load monitor, but TechSolve can bring more than this. It can measure forces more specifically and directly using a three-component dynamometer.
Force analysis can be useful for diagnosing the challenges of an application involving a difficult workpiece material and/or an unstable process. To the knowledgeable observer, force profiles can reveal the problem areas in a process—the shortcomings to address to make the process consistent and reliable enough for unattended machining.
In this video of machining 4140 steel, watch the cuts and see the force profiles corresponding to (1) gradual tool failure, (2) cutting with a rake angle that is too highly positive for the process and (3) the development of a built-up edge.
Tungaloy Adds Chipbreaker to Line of PVD-Coated Inserts
The PVD-coated insert grade series AH8000 performs in turning operations for heat resistant superalloys.
Tungaloy Expands Turning Tool Lines With Left-Handed Inserts
The TCS18 and TCL18 inserts are designed for left-hand cuts, expanding product lines that previously offered only right-hand inserts.
