Tower Storage System Accommodates Flat Goods of Various Sizes, Materials
Kasto will present solutions for the storage and machining of metal bar stock and sheets, including its automated KastoEcoStoreTower storage system for flat goods of various sizes.
The automated tower storage system is designed for high storage density, flexible clamping and fastening, and short access times.
The standard version accommodates materials as large as 1,524 mm wide and 4,000 mm long. The system and loading heights have a maximum of 8 m and can be chosen as needed. Users can specify up to three different heights between 50 and 950 mm per storage system. In addition to storing sheet metal, the KastoEcoStore can also hold containers such as euro-pallets and wire boxes, making it suitable for applications involving different materials. Its compact design enables it to be installed close to machinery and used as a buffer store between production areas.
The company will also feature its KastoWin pro AC 5.6 fully-automatic, high-performance band saw and the KastoApp, which enables users to monitor sawing machines via smartphone or tablet.
