Top Shops 2013: Davan Manufacturing
Learn about this year’s Machining Technology Honors Program Winner and its approach to capital equipment purchases.
Realizing Success by Applying Advanced Equipment
Davan Manufacturing, located in Washington, Pennsylvania, is this year’s Machining Technology Honors Program Winner. Mark Vanistendael, company president, says he has continued the approach to integrating advanced machining equipment that his father successfully applied.
David Vanistendael started the business in 1968. Over the years, the shop was an early adopter of leading technology as it became available, including NC and CNC machines as well as horizontal machining centers even though this required a significant investment in capital equipment. The approach gave the small shop a competitive advantage over others that used more traditional equipment.
Since Mark took over the company in 1996, the shop has focused on integrating equipment that enables parts to be completed in one setup. This has set Davan Manufacturing apart from others and helped it do more with fewer employees. This is important because the shop is located where there is a heavy concentration of manufacturers with a very competitive labor market. It’s challenging to draw quality, new employees, so the shop leverages machining technology that can perform multiple operations.
Key to this has been integrating turning centers with live tooling and C-axis positioning capability. The shop has also added vertical turning capability with live tooling for bigger work, feeling this is a natural extension of its approach to smaller-scale jobs. Because the vertical turning machine can perform milling and drilling operations, transport of big parts throughout the shop is minimized.
The shop isn’t shy about adding advanced machining capacity, but it thoughtfully considers whether a new machine is a good fit. For instance, typical batch sizes are 20 to 50 pieces, so a twin-spindle/twin-turret lathe wouldn’t make sense because the volumes aren’t there. Similarly, the shop doesn’t focus on exceedingly complex parts, instead pursuing more conventional work and trying to complete it on one machine. Therefore, it hasn’t seen a need for a turn-mill machine with a B-axis and toolchanger. That said, Davan Manufacturing has a healthy mix of machining technologies, and would be open to integrating a different machine tool platform if it matches emerging market opportunities as well as the shop’s approach to completing parts in one setup.
Company Description
Davan Manufacturing was established in 1968 in Washington, Pennsylvania. Its original business was the manufacture of screw-machine-type parts and light sheet metal fabrication for the electronics industry. Since then, it has become adept at machining precision components in short to medium volumes for industries that require high-quality, interchangeable parts at competitive prices. Part of this strategy is leveraging horizontal machining centers with pallet-changing capabilities and turning centers with live-tooling stations that can perform milling and drilling operations.
The company has a 17,500-square-foot facility with 13 CNC machines. Its machinists, programmers, inspectors and shopfloor support personnel have an average of 24 years of job shop experience. In addition to machining capabilities, the shop offers value-added engineering and design services for its customers.
End Markets Served
- Construction
- Glass
- Mining
- Oil exploration
- Power
- Steel
- Valve
Workpiece Materials Commonly Machined
- Aluminum alloys
- Copper
- Steel alloys
- Stainless steel
- Titanium
Davan Manufacturing
500 Crile Road
Washington, Pennsylvania 15301
Phone: 724-228-0115
Fax: 724-228-0190
IMTS Conferences - Monday
From innovation, quality and inspection to workforce development and company culture, Monday’s conference schedule has a lot to offer. Hannover Messe USA, the IMTS Conference, IMTS Job Shops and Women Make Manufacturing move all kick off today!
Read MoreNiche Work If You Can Get It: A CNC Machine Shop Crafts Its Own Destiny
Read MorePositioned to Prevail: Designing Processes Around People
Read MoreFinding Skilled Labor Through Partnerships and Benefits
To combat the skilled labor shortage, this Top Shops honoree turned to partnerships and unique benefits to attract talented workers.
