3 Design Elements for Effective Turning on a 5 Axis Machine
Here are three design elements that enable this five-axis machine to effectively turn workpieces, even if they aren’t symmetric.
![](https://d2n4wb9orp1vta.cloudfront.net/cms/realizingeffectiveturning.jpg;maxWidth=600)
The rotary table balance control system on this five-axis machine enables 600-rpm turning of non-symmetric parts weighing as much as 8,818 pounds.
I like to use numbered or bullet lists in my articles. These visual tools make it easier for readers to quickly scan an article for relevant information. It also makes the article shorter and easier to digest, in part because there’s no need to include transition sentences taking the reader from one paragraph to the next. Instead, key points are provided in meaningful little portions.
In a recent print article, I wrote about three design elements said to enable the MCT five-axis machine platform from Burkhardt + Weber, part of Industrias Romi SA, to be effective at turning operations. These include:
- Turning tool adapter (Because turning with a tool in the main spindle limits production and damages bearings.)
- Table balance control (Because parts to be turned on a five-axis machine often aren’t symmetric.)
- Thermal isolation system (Because introducing heat isn’t helpful here.)
Swiss-Type Control Uses CNC Data to Improve Efficiency
Advanced controls for Swiss-type CNC lathes uses machine data to prevent tool collisions, saving setup time and scrap costs.
Multitasking Machines Cut Days From Shop’s Setups
Adopting WFL Millturn machines enabled BWXT to condense operations and setups while also providing a simple way to simulate and secure processes.
