The Lowdown on Machine Tool Lubricants
Need help choosing the right lubricant for your machine tools and workplace environment? Here’s a resource to help keep your equipment humming along.
![](https://d2n4wb9orp1vta.cloudfront.net/cms/Kluber.jpg;maxWidth=600)
Proper lubrication management is central to the long service life of your machine tools. Choosing the right mix for the type of work you’re doing, as well as the environment you’re doing it in, will pay off in the long run. To aid in selection, Klüber Lubrication has developed a new content hub website that provides insights for a variety of markets into how the proper lubricant solutions save energy, protect equipment and enhance processes. The kind of information you’ll find includes:
- Product spotlights that describe lubricant properties and areas of likely applications such as couplings, joints and gears.
- Blog overviews from a Klüber expert about special application issues like the advantages of using synthetic ester oils, high viscosity index (VI) base oils or high-performance NSF H1 food-grade lubricants.
- White papers that provide in-depth information about test procedures, lubricant properties and application techniques.
- Case histories that detail successful application in various industries, climates and hazardous environments.
- News releases on the latest developments in lubricant solutions for new applications, government regulations and other timely issues.
Vomat Coolant Filters Provide Precise Temperature Control
The company’s filters ensure a continuous supply of clean oil for microtool grinding applications.
Oelheld Coolant Increases Metal Removal Rates
The odorless coolant is said to offer increased removal rates, lower electrode wear, excellent surface qualities, lower refill quantities and longevity to provide lower overall operating costs.
New Coolant Designed for Automotive Parts Production
Choosing the right coolant is critical for productivity, economic efficiency and machining quality.
