The Humble Pull Stud
I’ve said that the toolholder is the least appreciated element in many milling processes, but the pull stud (or retention knob) is perhaps the least appreciated component of the toolholder.
I’ve said that the toolholder is the least appreciated element in many milling processes, but the pull stud (or retention knob) is perhaps the least appreciated component of the toolholder. This video from Big Kaiser discusses the importance of the pull stud, different types of clamping on the stud, inspection and maintenance recommendations, and the factors that lead to pull stud failure.
Jergens Pull Studs Enable Quick Changeovers
SP140 and K02 pull studs offer quick-change solutions for vise or gripper jaws, electronic component manufacturing, packaging machines, medical technology and automation.
Tungaloy Grooving Toolholders Provide Highly Stable Machining
TungHeavyGroove includes an enhanced insert clamping design for maximum tool rigidity.
