Supermill Full Line Catalog
Primary Cutter’s Supermill catalog features high-performance carbide end mills with an extensive offering of radius sizes and diameters.
Nidec Universal Head Enables Versatile Machining
The compact universal head enables better accessibility between the tool and the workpiece, as well as improved surface-finish quality, greater motion range and high-efficiency machining under ideal machining conditions.
ANCA Creates Solid PCD-Tipped Helical End Mills, Drills
The company’s Edge machine is capable of creating complex 3D cutting tool forms, including solid PCD-tipped end mills and drills under 1 mm.
10 Tips for Titanium
