Steady as She Goes
Machine shops are inventive operations. Learn how one uses a steady rest in a different way on one of its two-turret CNC lathes.
![](https://d2n4wb9orp1vta.cloudfront.net/cms/uploadedFiles/DK_KitagawaSteadyRest.jpg;maxWidth=600)
![](https://d2n4wb9orp1vta.cloudfront.net/cms/uploadedFiles/DK_oilfieldcovershot.jpg;maxWidth=600)
That shop’s owner offered a candid take on turn-mills, by the way. Integrating turn-mills was one of the most challenging endeavors his shop undertook (but he’s certainly glad they did it). Learn more in this article.
