Specialized Lineup of In-Stock Lathe Tooling
Velocity Tooling offers LB series and LT series tooling designed specifically for Okuma lathes.
Velocity Tooling offers LB series and LT series tooling designed specifically for Okuma lathes. The LB series tools feature an individually ground front mounting plate and a spring-loaded rear mounting plate for quick and accurate tool installation. The LT-2000 tools feature set screws in the tool body, which are adjusted at the factory to pre-align the tool to the turret face. The tools can be run dry thanks to the design of the 1,160-psi coolant-through system.
Norton | Saint Gobain Abrasives' Wheels Increase Metal Removal
The Norton Winter Paradigm Plus Diamond and Winter G-Force Plus Next Generation Diamond Wheels expand the company’s grinding wheel options.
Walter Introduces New Insert Grades for Turning Steel
Walter offers three Tiger·tec Gold grades specifically designed for turning operations in steel and cast iron.
Walter Turning Grades Feature Curved Wiper Cutting Edge
The FW4 and MW4 positive wiper geometries provide a wiper action that can reportedly be used to reduce machining time by using double the feed rate.
