Solid Tool or Indexable Inserts? Why Not Both!
Kyocera SGS Precision Tools’ mill-turn demonstrations highlight varied tool choices and varied application knowledge.
When does an application call for an indexable-insert cutting tool rather than solid carbide? With both tooling types on display in a shared space – an IMTS first for the jointly branded company – Kyocera SGS Precision Tools is likely to have the answer. In addition to standard milling and turning offerings, SGS’s solid line includes sweeping-geometry, circle-segment “barrel cutters” and coolant-through drills, while highlights of Kyocera’s indexables range from end and face mills to grooving, turning and drilling tools.
With application knowledge as broad as the jointly branded product offering, booth representatives also stand ready to show rather than tell. Live cutting demonstrations of both cutting tool types highlight where and why each stands out, while also showcasing the inherent flexibility of a mill-turn machine capable of milling and turning with both indexable or solid carbide tools.
![A close-up of a carbide insert removing metal from a cylindrical compnent mounted in a lathe.](https://d2n4wb9orp1vta.cloudfront.net/cms/brand/mms/2022-mms/showdailysgskyo-kyoceraccx.jpg;maxWidth=720)
Solid tools like the one cutting the blisk are the province of SGS, while indexable offerings like the turning tool are Kyocera’s specialty. Photo Credit: Kyocera SGS Precision Tools
![A solid carbide cutting tool hovers above the blades of a metal disc.](https://d2n4wb9orp1vta.cloudfront.net/cms/brand/mms/2022-mms/showdailysgskyo-sgshpr.jpg;maxWidth=720)
Beards of IMTS - Amazing Feats of Beard Engineering
Manufacturing has a multi-talented bunch of people, but who knew so many were adept in the facial hair industry? Check out the best of the beards at IMTS!
Ball-End Tool Contours, Chamfers and Finishes in One Pass for Most Materials
The new IMCO Carbide Tool Pow•R•Arc end mill, to be shown at IMTS 2022, emphasizes speed. The cutter is able to run and increase feed rates to machine one’s mold up to five times faster than a four-flute tool.
Combination Lathe Enables Both Manual, CNC Operations
IMTS22: Milltronics showcases its ML16II/40 combination lathe, as well as its VM3018IL performance vertical machining center.
