Rotary, Index Tables Designed For Precision Machining Applications
Featuring photos, specifications and detailed diagrams, this catalog details Tanshing’s line of CNC rotary tables and index tables. The tables are equipped with the company’s dual lead worm drive system, which is said to provide rigidity, transmission torque and wear resistance during machining. Models are availabl
Featuring photos, specifications and detailed diagrams, this catalog details Tanshing’s line of CNC rotary tables and index tables. The tables are equipped with the company’s dual lead worm drive system, which is said to provide rigidity, transmission torque and wear resistance during machining. Models are available for HMCs, VMCs, special purpose machines and more with both pneumatic and hydraulic locking configurations.
Rail Manufacturer Moves Full Steam Ahead with Safe, Efficient Workholding Solution
All World Machinery Supply paired a hydraulic power unit with remote operating capabilities in a custom workholding system for Ahaus Tool & Engineering.
