Power Generation, Aerospace Milling Product Catalog
ATI Stellram’s catalog features indexable milling cutters and inserts specifically designed and manufactured for high-performance, difficult-to-machine materials, such as those used in turbine blades.
ATI Stellram’s catalog features indexable milling cutters and inserts specifically designed and manufactured for high-performance, difficult-to-machine materials, such as those used in turbine blades. The portfolio of Stellram milling tools is used in the aerospace, defense, power generation, oil and gas and other sectors in which common stainless steels and high-temperature alloys are common.
ANCA Creates Solid PCD-Tipped Helical End Mills, Drills
The company’s Edge machine is capable of creating complex 3D cutting tool forms, including solid PCD-tipped end mills and drills under 1 mm.
Sandvik Coromant Launches New Range of Solid End Mills
The CoroMill Dura range is designed for roughing and finishing with different engagements in all applications and materials.
