Nothing Boring about Boring
Under the right conditions, a precision boring operation can correct for a drilled hole that is slightly out of location.
Under the right conditions, a precision boring operation can correct for a drilled hole that is slightly out of location. That's one of the pieces of practical advice in "A Word about Boring Heads,” a short technical article by Criterion Machine Works. Boring equipment such as boring tools and heads are one of Criterion's specialties. The company knows a lot about boring operations and has captured some of this knowledge and wisdom in several articles on its web site.
For example, the article mentioned shows that the key to precision boring as a fix for an out-of-location whole is the ability of a boring head with single-point tool to remove more stock from one side of the hole than the other.
A companion piece, "A Word about Boring Tools," offers similar insights and recommendations. Its discussion about the importance of keeping the cutting edge of the boring tool on the exact centerline of the hole is clear and well-illustrated.
Walter Extends Line of Precision Boring Tools
The new boring tools employ modular components such as cartridge holders and extensions, which are matched to the system, utilize an extensive range of indexable inserts suited for precision boring and can be used for all material groups.
Kennametal Expands Modular Drilling Platform
The KenTip FS GTP insert allows for multiple machining applications across materials including steel, stainless steel and cast iron.
How Lowering Torque Improves Tapping Tool Life
Escaping the tap breakage trap requires a long look at torque and the many factors that influence it.
