Hybrid Lubricant Offers Advantages
An organic-urea-based, oil/grease hybrid lubricant can reduce machine maintenance costs and lead to longer coolant life.
At IMTS, I learned about an organic-urea-based (yes, urea) hybrid lubricant that takes advantage of oil’s liquid nature and grease’s adhesive characteristics. LHL (Lube Hybrid Lubrication) is available in the United States through Lube USA and is said to offer a number of advantages. It uses just a fraction of the lubricant quantity compared to conventional oil lubrications systems. The company says lower lubricant requirement can significantly reduce machine maintenance costs while minimizing the chance that lubricant will enter a machine’s coolant tank causing coolant deterioration and/or decomposition. Plus, the LHL hybrid grease doesn’t emulsify and is packaged in convenient cartridges that are simple to replace. Maintenance made easier.
Marubeni Citizen-Cincom Accessories Provide Faster Cycle Times
IMTS 2024: Marubeni Citizen-Cincom is showcasing a range of machining accessories designed to work intuitively with Citizen machines.
Hennig Inc. Acquires Industrial Coolant Systems
ICS develops and field tests high-pressure coolant systems, coolant filtration systems and other machine tool solutions.
STLE Hosts Co-Branded Tribology, Lubrication Events
The 2023 STLE Tribology Frontiers Conference and Tribology & Lubrication for E-Mobility Conference will provide attendees with two opportunities to share and learn the latest tribology and lubrication engineering science.
