How Much Can Unattended Production Add?
Using a horizontal machining center, this shop kept production going through two 10-hour shifts per day. That seemed like a lot, but a pallet system enabled the shop to go even further.
![](https://d2n4wb9orp1vta.cloudfront.net/cms/HowMuchCanUnattendedProductionAdd.jpg;maxWidth=600)
A shop running two 10-hour shifts has just about all of the day covered. That was the case with Aztalan Engineering. Using a horizontal machining center—with parts loaded on one pallet while they are being machined on the other pallet—offered a way to keep production going throughout all of the staffed hours. However, for a manifold part needed in relatively high volume, the shop went even farther than this. It added a Fastems pallet system so it could keep on feeding the machine even through the unattended hours. Capturing this seemingly small number of additional hours had a significant impact on capacity. The additional 4 hours per day, plus an extra 6 hours over the weekend, increases the weekly output of this machine by more than 25 percent over what a standalone HMC could do, even an HMC staffed by an operator for 20 hours per day.
Read more about automation at this shop.
Horizontal Turning Center Ready for High Production
Romi Machine Tools’ new GL300 S features high-power torque and feed force and is built with a robust monoblock base for ultimate rigidity and precision.
The Debut of an HMC Series
The FH5000 Series from JTEKT Toyoda is compromised of three high-speed horizontal machining centers.
