![A 3D-printed motor stator](https://d2n4wb9orp1vta.cloudfront.net/cms/brand/mms/2021-mms/mms-0121-knustgodwin-1.png;maxWidth=720)
A 3D-printed motor stator (and detail) — a mission-critical turbomachinery part — printed by Knust Godwin on a Velo3D Sapphire laser powder bed fusion machine. Compare the lack of weld joints to the image below. Photo Credit: Velo3D
When we think of “mission critical parts,” we might conjure images of turbine blades, combustors or mechanical control systems that are typically associated with aviation and spaceflight. In other words, parts in which failure results in some form of human catastrophe.
The real definition is much less dramatic: Mission critical parts are simply parts that are essential for the operation of an application. These can include impellers, pumps and manifolds for industrial applications from washing machines to turbomachinery.
For the past 50 years, Texas-based Knust Godwin has specialized in the precision machining of mission critical parts for the energy, aerospace and oil and gas industries, including turning and drilling operations for complex geometry parts produced out of Inconel, titanium and other exotic materials. Because of their composition and design complexity, these parts typically incur steep costs and require long lead times associated with obtaining castings and building the necessary custom workholding.
![A traditionally manufactured motor stator](https://d2n4wb9orp1vta.cloudfront.net/cms/brand/MMS/2021-MMS/MMS-0121-KnustGodwin-2.png;maxWidth=385)
A traditionally manufactured motor stator contains dozens of weld joints, each of which is considered a risk failure if not executed properly. Photo Credit: Knust Godwin
It was this combination of part complexity and high value, combined with the low volumes these parts generally require led the company to begin experimenting with additive manufacturing (AM) around 2010, specifically with powder bed fusion metal AM processes. Mike Corliss, the company’s vice president of technology, says that the decision to incorporate metal 3D printing into its production capabilities was simply a natural evolution toward new technologies, not unlike the transformation that computer numerical control (CNC) machining or even new types of cutting tools had on the industry decades ago.
“You need to look at your products and ask, ‘Does (additive) make sense?’ You've got to have the vision and you have to be able to realize the capabilities of this technology,” Corliss says. “I remember 40 years ago, getting my boss back in the day to consider inserted cutters. He didn’t like the cost, but then he saw the output of an inserted cutter and suddenly it was, ‘Buy more, buy more!’ With additive, I think once you understand its capabilities, it will be the same scenario: Buy more, because you can see the results of AM.”
![3d printer at knust godwin](https://d2n4wb9orp1vta.cloudfront.net/cms/brand/mms/2021-mms/mms-0121-knustgodwin-1.jpg;maxWidth=720)
One of Knust Godwin’s Sapphire 3D printers on the shop floor.
17 Steps Removed
Corliss specifically points to turbomachinery and heat exchangers as examples of AM’s ability to bring production efficiencies versus traditional manufacturing methods. Producing a traditional heat exchanger involves several processing steps, from cleaning the raw material to prepare it for brazing, then welding, machining, stacking and testing. Corliss says that, in total, the traditional manufacture of these parts includes 26 steps of what he calls labor touch time from beginning to end.
When the company began 3D printing heat exchangers, Corliss says, it was able to consolidate the process from 26 steps to nine. “We print it, prep and clean it, wire EDM to remove supports if necessary, then heat treat it and machine the final surface finish before pressure testing,” he says. To reduce the process steps even further, the company purchased Velo3D Sapphire printers that enable support-free printing for geometric overhangs. Control over characteristics of the laser and other 3D printing build parameters in-process allows this machine to adapt in real time to sometimes overcome the need for support structures that typically anchor metal 3D printed parts against thermal distortion during printing — supports that later need to be removed. Corliss says that the system has allowed the company to increase efficiency due to the freedom to print thin walls and low angles without supports and without the lengthy post-processing steps needed for support removal.
![This chart shows the difference in the amount of process steps needed to produce a conventional plate-fin heat exchanger versus a 3D-printed part.](https://d2n4wb9orp1vta.cloudfront.net/cms/brand/MMS/2021-MMS/MMS-0121-KnustGodwin-4.png;maxWidth=720)
This chart shows the difference in the amount of process steps needed to produce a conventional plate-fin heat exchanger versus a 3D-printed part. Photo Credit: Velo3D
“We have much tighter process controls with this ability,” Corliss says. “If we can reduce the postprocessing, then the product at the end of the day is going to be much better and move much more quickly out the door.” He continues, “Removing supports on some products that we've printed could take longer than what it actually took to print the part. Next generation additive is allowing us to be able to take on these parts.”
Corliss also points to the uniformity of downskin surfaces printed on the Sapphire systems — surfaces such as low-angle overhangs on 3D printed impeller blades — as key to reducing customer costs and lead times. 3D printing is able to generate the surfaces more precisely than castings. Learning which surfaces need to be machined to decrease roughness versus those that can now be left as-is has played a big role in Knust Godwin’s adoption of metal additive manufacturing. Corliss says, “We had to learn how to adapt: What do we postprocess, and what do we leave as-printed? We had to educate our shop floor guys and all of the operators — this is where we’re leaving stock, this is where we’re not leaving stock.”
![3D printed heat exchanger](https://d2n4wb9orp1vta.cloudfront.net/cms/brand/MMS/2021-MMS/MMS-0121-KnustGodwin-3.png;maxWidth=385)
By utilizing support-free metal 3D printing for this heat exchanger, Knust Godwin was able to reduce post-processing time and part cost while increasing performance. Photo Credit: Velo3D
Corliss says that even though the company decided to retrain existing staff to run its 3D printers rather than hire AM specialists, by that point the toughest hurdle toward adopting AM had already been cleared: convincing leadership that AM was worth the investment. The only way to make an informed decision, Corliss says, was to create a detailed cost analysis comparison, part by part and step by step, between subtractive and additive processes. The majority of parts at Knust Godwin are still produced traditionally, but the analyses revealed that AM proved to be a better value proposition across a range of the company’s products.
“We analyzed all the costs involved with a product. How much does a weld joint cost? Say a weld joint costs an average of $100 and you have 20 on an individual part. Now, what is the cost if that weld joint fails?” He says that the company’s design engineers have become proficient with combining previously welded components into a single part, removing critical weaknesses and strengthening the part’s overall integrity. For Knust Godwin’s customers, especially its customers in the oil and gas industry, this has been key to their own willingness to adopt 3D printed parts for field operations.
![Knust Godwin's machine shop floor](https://d2n4wb9orp1vta.cloudfront.net/cms/brand/MMS/2021-MMS/MMS-0121-knustgodwin-2.jpg;maxWidth=720)
CNC machining operations at Knust Godwin.
“How much would you be fined by your customer for a field shutdown? We never want to have to answer that question,” Corliss says. “The late penalties, the infield replacement costs that you would incur if you had a product that just failed — you just don't want to ever have to deal with that. So that's why we have to make sure that the build quality of our AM parts meets or exceeds the requirements of traditional, subtractive parts.”
I recently talked with Mike Corliss about this and related topics during an IMTS spark presentation within a series called AM In-Depth. To view the presentation, find it on IMTS spark and add it to your My Spark Planner.
![All IMTS spark programming runs through February, 2021. Visit IMTS.com/spark to register.Photo Credit: IMTS spark](https://d2n4wb9orp1vta.cloudfront.net/cms/brand/MMS/2021-MMS/MMS-0121-KnustGodwin-5.png;maxWidth=720)
All IMTS spark programming runs through February, 2021. Visit IMTS.com/spark to register. Photo Credit: IMTS spark
Read MoreUnderstanding The Four Major Behavioral Styles
Companies today are expanding the role of teams in the workplace in an effort to empower employees and improve organizational effectiveness. The more we try to work as a team, the more important it becomes to recognize that people exhibit different behavioral styles.
Read MoreThreading On A Lathe
SLM Solutions Showcases Possibilities of Metal 3D Printing
SLM Solutions is exhibiting metal 3D-printed parts that illustrate the capabilities of powder-bed fusion systems.
Read MorePositive Changes in the Precision CNC Machining World
New PM magazine editor-in-chief. New PMTS trade show location. Newly proposed PMPA management services strategy. Positive momentum continues to build to best serve and move this industry forward.
Read MoreMission Critical: An Additive Manufacturing Breakthrough in Commercial Aviation
The GE9X is the first commercial aircraft engine to reach production with significant additive content. The story of GE’s accomplishment and why it matters.
