Get the Handbook on MQL
A free handbook from Unist explains the benefits of minimum quantity lubrication and offers advice for those interested in moving away from conventional flood coolants.
![](https://d2n4wb9orp1vta.cloudfront.net/cms/DK_UnistMQLHandbook.jpg;maxWidth=600)
Minimum quantity lubrication (MQL) is used more in Europe than here in the States due to stricter environmental regulations across the pond. However, MQL has a proven track record in working just as well as, or better than, traditional flood coolants for certain applications. Plus, shops don’t have to deal with negative consequences like health hazards, disposal costs and pricey circulation equipment. If you’re interested in learning more about MQL, consider signing up to receive the “MQL Handbook” offered by Unist, the Grand Rapids, Michigan manufacturer of MQL systems for metalworking applications.
The handbook explains how MQL differs from conventional coolant methods, how it works, what equipment is needed, how to develop an MQL process and what fluids work best for it. Sign up to receive the handbook here.
Hennig Inc. Acquires Industrial Coolant Systems
ICS develops and field tests high-pressure coolant systems, coolant filtration systems and other machine tool solutions.
Managing Coolant with Skimmers, Refractometers and More
Bacteria-infected coolant harms machines and sickens machinists. Coolant management technologies like skimmers and automated systems counter this tendency.
Unist's Electronic Control Regulates Lubricant Delivery
Unist’s Pulse R electronic control ties into the system control solenoid valve and takes the place of a pneumatic pulse generator timer or logic block.
