End-Mill Milling Highlights Five-Axis Capability
Kern Precision IMTS booth visitors can submit worn tools for a demonstration of what is possible when linear motors combine with micro-gap hydrostatics.
Machining worn end mills on the show floor might seem like a promotion fit for a tool grinding company, but Kern Precision does not specialize in tool grinders. Rather, its focus is high-precision five-axis machines like the company’s Micro HD, which cuts materials that might otherwise be deemed ill-suited for machining – namely, sintered carbide and ceramics. To prove the point, the company invites visitors to bring in their own tools to use as “workpieces” for a contour-cutting demo.
![Dust-like piles of chips surround a fluted tool boring into a tungsten blank held in a chuck on the table of a CNC machining center.](https://d2n4wb9orp1vta.cloudfront.net/cms/brand/MMS/2022-MMS/kernshowdailysm.jpg;maxWidth=720)
A tool from 6C, which uses laser ablation to increase flute count and achieve sharper edges, drills into tungsten carbide on Kern’s Micro HD five-axis machining center. This machine is also useful for milling, drilling and thread-milling sintered glass and ceramic. Photo Credit: Kern Precision
Although this demonstration focuses on two relatively slim diameters – ¾” and 20-mm end mills – Kern’s ambitions for its new machine are anything but small. Linear motors and micro-gap hydrostatics (claimed to be a unique combination for a “true” five-axis machine), as well as fundamentals like thermal stability, dynamic acceleration and stick-slip-free motion, offer the possibility to replace other, more time-consuming processes.
One application where the Micro HD improves upon older, slower processes is the machining of punches for cutting inserts and medical tablets that were once produced via EDM. Another is cutting threads to an accuracy of less than 1 um in relatively brittle, 40%-silicon aluminum alloy for space telescope components.
Ball-End Tool Contours, Chamfers and Finishes in One Pass for Most Materials
The new IMCO Carbide Tool Pow•R•Arc end mill, to be shown at IMTS 2022, emphasizes speed. The cutter is able to run and increase feed rates to machine one’s mold up to five times faster than a four-flute tool.
NASA Brings Technology to New Heights
Meet NASA mission system engineer Mike Menzel and learn more about the James Webb Space Telescope at Mitsui Seiki USA’s booth (338700) in the South Hall from 11:00 a.m. to 11:45 a.m. on Thursday, September 15.
