CYCLO CUT HSK63A End Mills
(Sponsored Content) CYCLO CUT cutting tools offer integral shank HSK63A end mills for use in high speed machining of large aluminum structural components. Integral design allows indexable cutting while running at high RPM’s, and much higher cutting capabilities. Cutters are available up to 2.00” in diameter with reaches of 2.00” to 4.00”.
CYCLO CUT cutting tools include a complete line of indexable cutting tools for the automotive, aerospace, agriculture, wind and general machining industries. We offer an extensive line of end mills and face mills including integral shanks for CAT 50, HSK63A and HSK100A. Ideal for machining centers and special purpose machines, our cast iron 55 degree face mills range from 3.00” to 20.00” in diameter. MAG’s 6.00” diameter face mills with 21 teeth will semi-finish at 107 IPM and 630 RPM.
CYCLO CUT cutting tools also include a complete line of standard and high performance solid carbide end mills and drills with over 3,000 different sizes and lengths in stock for immediate delivery. Our rotary tooling portfolio includes HSS cobalt and powdered metal end mills, capable of up to eight hours tool life roughing titanium and other high temperature alloys. MAG also has a large selection of PVD coated tooling for composite machining, and a tool holder portfolio including CAT 40, CAT 50, HSK 63A, HSK 100A, HSK 125A, BT40 and BT50.
Cutting tools best perform in combination with CYCLO COOL metalworking fluids proven to increase tool life by 200% over the competition. CYCLO COOL includes a complete line of coolants, corrosion inhibitors and cleaners for all the manufacturing industry.
To receive CYCLO CUT and CYCLO COOL product catalogs or for more information please contact Will Gruber at 859.534.4597, Will.Gruber@mag-ias.com, or Roger Romas at 859.534.4574, Roger.Romas@mag-ias.com or email a request for quote to info-psus@mag-ias.com.
Nidec Universal Head Enables Versatile Machining
The compact universal head enables better accessibility between the tool and the workpiece, as well as improved surface-finish quality, greater motion range and high-efficiency machining under ideal machining conditions.
