Coolant-Through Carbide Drills
OSG’s coolant-through carbide drills are available with WD1 coating, which inhibits the wear on the shoulders and margin, or TiAlN coating. Two flute lengths are available: Exocarb-FTO 5D and Exocarb-FTO 3D.
OSG’s coolant-through carbide drills are available with WD1 coating, which inhibits the wear on the shoulders and margin, or TiAlN coating. Two flute lengths are available: Exocarb-FTO 5D and Exocarb-FTO 3D. The 5D lineup includes diameters sized to drill pilot holes for rolling taps, and the 3D line consists of 2.8- to 16-mm diameters in 0.1-mm increments. Sizes larger than 16 mm are available in 0.5-mm increments.
Finding the Right Tools for a Turning Shop
Xcelicut is a startup shop that has grown thanks to the right machines, cutting tools, grants and other resources.
Orthopedic Event Discusses Manufacturing Strategies
