Comparing Apples to Apples
Consistency is key to properly evaluating the effect of any process change.
![](https://d2n4wb9orp1vta.cloudfront.net/cms/uploadedFiles/SGS-blog.jpg;maxWidth=600)
George Smith, president of EGW, says he is confident in his comparisons of the SGS’ Z-Carb mills and the previously used tool is because both ran for an extended period of time in the same conditions on the same machine: the Fadal VMC visible here.
Product literature abounds with claims about reducing cycle time or improving productivity by such-and-such percent. Assuming the supplier is reputable, such data aren’t conjured from thin air; they’re the result of extensive testing. And any proper testing will apply a principle that we all (should have) learned in science class: it’s imperative to keep all process variables constant except the one being evaluated.
That’s worth keeping in mind when evaluating a new product on your own shop floor. Consider this case study, which details the benefits firearm component manufacturer Evolution Gun Works (EGW) gleaned from a new end mill. The reason company founder George Smith can be so confident in the capabilities of the new tool boils down to process consistency. As Mr. Smith puts it, “We have a good gauge on end mills because we’ve been running the same job on the same machine with the same material for four months straight.”
Sandvik Coromant Launches New Range of Solid End Mills
The CoroMill Dura range is designed for roughing and finishing with different engagements in all applications and materials.
Shoulder Milling Cuts Racing Part's Cycle Time By Over 50%
Pairing a shoulder mill with a five-axis machine has cut costs and cycle times for one of TTI Machine’s parts, enabling it to support a niche racing community.
10 Tips for Titanium
