CNC Tool, Peel Grinders Offered
Rollomatic will provide information on its CNC tool grinding and peel grinding machines, as well as updates to its fine laser cutting and ablation machine.
Autodesk, Inc.
View MoreRollomatic will provide information on its CNC tool grinding and peel grinding machines, as well as updates to its fine laser cutting and ablation machine. The GrindSmart five- and six-axis tool grinding machine offers versatility for virtually all kinds of rotary and stationary cutting tools, including end mills, drills, form tools, indexable inserts, taps, reamers, routers and medical instruments. The ShapeSmart NP5 five-axis peel grinding machine offers high concentricity for pinch grinding even long and thin parts. Rough and finish grinding can be performed in one pass, avoiding two separate processes and reducing cycle times. The company’s LaserSmart five-axis CNC fine laser cutting and ablation machine is designed for super-hard materials such as PCD, PCBN, CVD and natural diamond.
Ceratizit Waterjet Nozzles Cut Difficult Materials
The HyproJet range features three standard waterjet nozzles designed to provide narrow hole tolerances, optimized cutting and radial run-out accuracy.
Foba Laser Marking Solutions Enable Efficient Industrial Product Marking
IMTS 2024: Foba is demonstrating its laser marking solutions in a range of sizes, from compact to large. Its V series is said to optimize precision and performance in a compact model.
Where Micro-Laser Machining Is the Focus
A company that was once a consulting firm has become a successful micro-laser machine shop producing complex parts and features that most traditional CNC shops cannot machine.
