CNC Cylindrical Grinding Machine
Palmary’s brochure features the OCD-3260CAM CNC cylindrical grinder that can grind various special-shaped workpieces.
Palmary’s brochure features the OCD-3260CAM CNC cylindrical grinder that can grind various special-shaped workpieces when combined with accurate C-axis angle control of the spindle. The spindle uses a rotary encoder that offers angle control precision of 0.1µm. A high-speed algorithm controller running PC-based Windows XP enables easy input of third-party software.
